battery and ceetol
My boat(18ft) has an 8hp outboard with charging coil and rectifier.It is wired with nav lights, internal flourescent lights, vhf radio and car radio.All I need to do is
connect the battery terminals to a battery and replace the fuses.Is there a cheaper alternative than marine batteries?How should a battery be mounted on a boat?
Finally, what will clean a brush after ceetol, even acetone leaves it sticky?Thanks again in advance
