lw395
A lot of what he says about electricity makes sense though, I couldn't do without his bible: http://amzn.to/1g7B7gH
I think if this scenario is going to cause a problem would depend on the batteries, and the way they are wired. I would make sure to wire them with the charge/discharge cables at opposite ends, and use large capacity cable for the interconnects.
Fair comment, but I think it also depends on how the battery bank is to be used, and what you consider to be 'a problem'.
Also what does that 'problem' cost you over the lifetime of yacht ownership, vs what does it cost to avoid the problem.
Some battery banks in industry get used much more heavily than a yacht's batteries.
For instance, think about the batteries in an uninterruptible power supply, which are designed to get flattened in just a few minutes before the generator kicks in. The consequences of those not sharing properly could be expensive beyond the value of the batteries.
I suspect the rule is good guidance if you want to parallel starter batteries, but probably just a nicety for most lightly used house batteries.
House batteries that get spanked by heavy loads like big inverters might be a grey area?
