Poey50
Some of the "drop in" LiFePOs do come with a BMS but I believe most (all?) do not monitor individual cells but just the 12V unit. According to the "experts" the individual 3.2V cells can get out of balance in a 12 combo which can lead to imbalance in charging and death of the cell.
Here's a link to a very interesting, somewhat technical article written by someone that sells and installs LiFePO systems.
Of Service to you, Professional Engineering Opinion on AGM vrs Lithium - Cruisers & Sailing Forums
No that really isn't correct. I'm afraid the posts you linked to sounds like someone who should be taking lithium rather than installing it. Go back in a week or two to see the replies - that group does have some experts, I don't think he's one. People with the experience he claims don't tend to do 180 degree screeching U-turn in their explanations.
But I also don't think you have understood him correctly. If an internal BMS was only monitoring voltage at pack level rather than cell level then the battery would not last long. Pack level management has been tried but becomes a problem when cells begin to go out of balance. So for example a battery protect that stops a charging source at 14.6 volt sounds OK in principle since no cell will go above 3.65v. But that is only true if the cells are balanced. Once imbalance sets in then the four cells might be at 3.5, 3.5. 3.5 and 4.0 and still be charging. The fourth is being damaged. So internal BMSs work at cellular level and have some balancing capacity between cells.
