William_H
Float voltage is a permanent on charge voltage, charging from the engine will not need this as running time is limited by fuel tank.
The other thing to remember is that the voltage you see when charging from the alternator is not DC, it is half a sine wave, the top section above the DC voltage is the bit that charges the battery. So say the DC meter says 14.2 - 4 volt, the peak measured on a scope can be 15.5 - 16 volt, hence the high gassing with high levels of alternator boost.
It's the pulse above the DC voltage, that allowed us to fully charge a standard flooded battery with a mains charger running 14.3 volt.
Brian
Well actually the output of the alternator is the result of 6 half cycles squeezed together in time. Each AC cycle being full wave rectified has in effect 2 pos half cycles
for each ac cycle. But then during that one ac cycle you get another 2 identical versions superimposed each at 120 degrees apart. So actual DC out is much closer to smooth DC than just one half cycle. However as you say this waveform can confuse a digital voltmeter but if it is measured while connected to a well charged battery you can measure accurately what you need to know. ie charge voltage.
Quote Originally Posted by William_H View Post
However that will not help your engine battery connected to the alternator at 14.2 volts.
The Sterling blurb says there's a diode in the starter path, so that will at least cut the voltage a little.
I doubt this and surely only if you fit a diode between alternator and engine battery. I think the idea of AtoB charger is that you do not disturb the standard system ie alternator to engine battery but simply connect to it. The concept of charging the engine battery for a period then starting to charge the domestic battery via AtoB charger is just advertising spiel for saying that the AtoB does not start to work until engine battery recovers its voltage up to probably about 13.0 volts. ie just like a VSR. And if engine battery drops in voltage the AtoB will stop sucking current until it recovers. olewill
