prv
OK, this question is inevitably a big can of worms, but I can't decide what to do and maybe chewing it over in the forum will help.
Ariam's snakes' wedding of a battery bay has now been ripped out. Something better than the pair of bog standard 60Ah car batteries she came with is clearly indicated.
The space is a bit of an awkward shape, made worse by the fact that cables and hoses emerge through the base of it in annoying but immovable locations - but I want to pack as much battery into it as possible. I've determined that the best way to do this is with three 110Ah Red Flash Deep Cycle batteries from DMS Tech, stood on end (DMS confirm this orientation is acceptable). There is just space left in the bay to also fit a small Red Flash High Rate to start the engine. I'm not violently anti-flooded-lead-acid, but they can't be stood on end to fit the space and the non-spill, fit-and-forget nature of the AGMs is attractive. I don't have much space for acid-proof inner boxes and the like.
Charging will mostly be from the engine, a D1-30 with a 115 amp alternator. According to the manual (I've not measured) it's regulated at 14.2 volts. I'll fit a mains charger as well, but we don't currently have permanent power at our home berth so this will mostly be used when visiting marinas elsewhere (and I often prefer to anchor).
Obviously I want to pack as much power into the batteries as possible in a short engine run down the river.
DMS don't really publish full data on their batteries (in an email I asked for more information but not much was forthcoming). In the photo on their website it can be seen that the battery has the following printed on it:
Those are the facts. Now, how do we synthesise them into an effective charging system?
My natural leaning is towards a voltage-sensitive relay (or the Smartbank equivalent). Gibbo is persuasive when he argues that fancy chargers are not necessary when you have a modern alternator that already charges at over 14 volts (they were useful in the past when alternator regulators were set lower than that). However, DMS advise against this on the grounds that the engine battery will be overcharged while filling up the service bank. That said, I think they're missing the point anyway in that the voltage seen by the engine battery (and the service battery, come to that) will be 14.2 volts regardless of what phase of charge anything is in, because that's what the alternator is regulated to. So if I were motoring across a windless Channel, once I'd filled the service bank I'd be overcharging (by their standards) all four batteries, with my 14.2v alternator.
DMS (or at least the individual I exchanged emails with) didn't really seem to know much about the small sailing boat electrical environment, but they were very keen on smart chargers, saying that even modern cars essentially have smart chargers controlling their alternators. So I guess in our context that means something like the Sterling Alternator to Battery Charger. Claims of recharging the battery five times quicker (than what? A hamster on a wheel?) are attractive, if not wholly believable. But once that bulk charging is done, my understanding is that the A2B doesn't actually control the float voltage, it just turns off its boosting and passes through whatever the alternator is producing. Which DMS assert will kill their batteries. I filled in Sterling's "email" contact form asking for advice, and got sweet FA back.
Is the Volvo alternator simply incompatible with AGM batteries?
I know we have a couple of people with deep battery knowledge on this forum; I hope they will see this and comment.
Whatever I say I know everyone else will chip in their 2 penn'orth anyway
One piece of information that they did offer was "the voltage applied to one of our batteries should not exceed 13.8V when it is fully charged in order to avoid gassing". Obviously in a sealed AGM where you can't replace the water, gassing = damage.Charging (Constant voltage)
Float Charge: 13.6v - 13.8/25ºC
Cycle Charge: 14.5v - 14.9/25ºC
