ChasB
Hi folks!
I've just fitted a new sink, and got a leak!
The top hose is from the tap.
The brass thing just below is a male/male sex changer that measures 204mm (0.8in) across the outside of the thread. The white stuff on the thread is plumber's tape
The plastic connector at bottom is the hose from the boat's plumbing. The hose has a 5/8" outer diameter.
The leak is from the bottom of the plastic connector. Maybe I overtightened it.
I think I need to cut the plastic hose and replace the connector. I'm a novice to plumbing, but a keen learner.
What bits do I need to go out and buy?
Many thanks!
Many thanks!
