MYStargazer
OK, here's a diagram of how to use simple on/off switches, together with a diode splitter.
This looks like a very neat solution. Do you have a similar diagram for a twin engine setup?
I have pvb's circuit (without the emergency switch). To Vic's point in #12, I continue to ponder which battery to sense (I have a Valeo alternator with the splitter mounted on the back of the alternator with a post-diode sensing wire feeding the alternator regulator).
Whichever battery is sensed, the other will probably be undercharged.
If the emergency switch is closed for charging then both batteries will charge well but the isolation of the crank battery is compromised. (As an ex-satellite designer, I loathe possible single points of failure).
QUESTION: Is there a least worst connection for the sense wire (or am I missing something)?
More an anecdote than twopenny-worth but;
Our old bus came with very detailed, complex instructions about which switch to slide where when the engine was on, when the engine was off, when the boat was left, bla bla bla. It always worried the bejasis out of us and we'd often find ourselves padding about starkers in the middle of the night checking we had not forgotten to switch something when the engine went off...
A small fire gave us cause to have the boat checked by an electrician who told us that all the instructions were baloney and our 12BO switch had no bearing when the engine was running or not. Our 12BO switch only controls the input to the batteries from the shore power charger. The engine has two alternators permanently charging each bank via regulators (from the Arc), he said.
We can link the batteries for emergency starting via a difficult to get to procedure which protects it from mistakes.
However, despite the electrician's assurance that the 12BO switch does nothing when the engine is running, I have noticed that the two banks are linked when set to 1+2 because if the engine is on, the charge to the house batteries is higher (off or 1 or 2 it is 'normal') or if the house bank is fully charged from the wind gen, and the 1+2 is then selected, the engines batteries will draw some juice from house.
It seems to works, but something feels a bit out of whack about it all which is partly why we had the whole thing checked by a spark. Charging and batteries are the bane of my sailing life!
I think it was probably me who said about controlling the output with the 12bo as that is the way I have always set my boats up. The output goes to the starter and nowhere else. The diode splitter sends the charge to both batteries and the alternator charge is regulated through a Stirling alternator regulator with the sense taken through from the house bank. As the output only goes to the starter I can't see a problem with high current due to the batteries being paralleled. It would only be in that position in an emergency anyway and I have never had the need to select anything other than the starter battery.
Might be worth checking Furneaux Riddall although they don't list made up cables on the website.A great thread and a very simple diagram. While this is topical, and to save me posting another thread, can any of you recommend a good online store for battery leads? I would wish to avoid buying a heavy duty crimper so any of you that can recommend one which crimps terminals that would be fantastic!
Going back to basics, looking at pvb's schematic: how does that tie in with the circuit diagram for my ignition circuit?
Here you can see the engine battery goes to the solenoid (I am assuming that this is the same as 'starter' on pvb's diagram), and the alternator goes to the same point.
Also, isn't the alternator (regulator) now trying to charge two battery banks at the same time? Surely what I want to be able to do is tell the alternator which bank to charge. Over 24 hours I might want to charge my starter for 6 hours and then the remaining 18 hours put into the house. I have sealed lead acid starter and open lead acid house.
So how does PVB's solution know when to stop charging the starter but continue charging the house? If the Balmar is installed won't it get confused if it's trying to boost the house and float the starter?
Is it hi-jacking to ask what does 100A@ 24V mean on an isolation switch? Does that mean it can take 200A @12v?
