pmagowan
I have two, one in the Garmin wind vane and another plastimo clock style one. The Garmin shows 1026 while the plastimo shows 1050. How do I know which is right or do I need to buy a third and average the closest two?
It used to be a requirement that every Harbourmaster had to keep a calibrated and corrected barometer ( altitude, temperature ) in the office so that ship's masters could check/calibrate their own. It's worth checking IMHO what your local office has to offer....
And if you find a harbour where the 'balls' are still dropped to signify the moment of noon, so that ships' chronometers can be checked, do let us know.![]()
They should not read exactly the same - pressure drops surprisingly quickly with increased altitude ...
I think you should calibrate them both against an accurate actual observation. Amongst other stations, airports give frequently updated actual pressure readings as these are vital for safe air navigation. They form part of the weather report knows as a METAR (Met Actual Report) updated frequently for all main airports - its buddy the TAF is a Terminal Area Forecast and isn't what you want. Pick an airport as close a possible to you geographically. Then look for the QNH as it's called. That's what the pressure is at the airport but at notional sea level - so for example if the airport is 200 feet above sea level, it's what the pressure would be at the bottom of a 200 foot well at the airport. This enables the aircraft to set its altimeter so it reads how high the aircraft is above sea level when near the airport. The other pressure is QFE or threshold pressure. That tells you what the pressure is when sitting at the start of the runway. It's not what you want (because your boat is at sea level, not at the height of the airport) but it's important to the fly boys when the aircraft is landing as obviously if the altimeter is zeroed to that pressure, it reads zero feet altitude as the aircraft's wheels touch the ground.
You need QNH - actual reported pressure at the airport adjusted to sea level - not QFE - pressure at the elevation of the airfield.
For example I've just googled 'METAR Southampton' and got 'METAR: EGHI 262050Z 29003KT 260V330 CAVOK 16/10 Q1029'. The only two bits you need are the date/time '262050Z' which is 26th of month 2050 UTC or Zulu as the fly boys call it, and the 'Q' which is QNH or sea level pressure at Southampton - namely 1029 hectopascals or millibars as old guys like me call them. EGHI is code for Southampton but we don't need to know that as we aren't reading it off a list on a teleprinter and Google gives us the right report.
Failing that method (which is the easiest) you could always use forecast pressure for example from GRIB file but that is just a forecast. Met actual observation is fact.
So If you're in Cowes or Hamble, your barometer should have been reading 1029 at 2050 UTC, that is about 40 minutes ago. If the pressure is changing really fast, you might need to know what your barometer was actually reading 40 minutes ago, but in most circumstances half an hour doesn't make much difference. So you simply twiddle the little adjustment screw at the back so the barometer reads 1029 like the METAR says it should.
Bingo.
Hope that helps.
Bingo.
Hope that helps.
An Airband radio is very useful in this regard. The airports give these reports out in plain language on a repeating loop which is updated with any change in conditions. Windspeed and direction, cloud amounts and height, dewpoint etc are also included.
