NUTMEG
My CW 28' ketch has a ballast ratio of 33.3% and a white sail area of 400 sq ft. The ballast ratio of all the other CW's is higher, in the case of the CW25 a lot higher at 49.6%. The 28's sail area is also higher then all the CW's apart from the CW34 which carries 500sq ft. but is of course a lot bigger.
So am I right in thinking the 28 is going to be a bit more tender under sail but should be the best sailor of the marque?
In laymans terms for the hard of thinking what practical effect does ballast ratio have? Is it simply that higher figures mean she will stand up to her sails better and/or does it have an influence on her ability to recover from the unlikely effect of a knock down? The 28 has two tons of ballast in her hull plus a thumping great VP as well as two fuel tanks carried very low down.
What I really want to know I suppose is is she a good sea boat for theoretical off shore passage making, I am thinking east coast to Iceland at some indetermined point in the future. We all need dreams after all.
Steve
Steve
