ducked
Wickipedia says they used boiled linseed when the bridge was built (I suppose with red lead). I was going to try that with aluminium but eventually decided not to, since the sunflower oil seemed to withstand the effects of rain exposure fairly well while still wet, and eventually sets, though slowly.A example from near you @ducked.
The Forth Rail Bridge has been coated with a glass flake epoxy formula paint which should suffice for about 25 years. It replaced an inferior paint system that had been in use since the bridge was built. These types of coatings are useful and many have used similar technologies on their keels to increase time between coatings, which is their main advantage. Of course there are lower cost options which will work but maybe requiring more frequent attention.
I have used it on the more exposed mast taburnacle, and will give it another going over when I take the mast down. Considering also using it on the boom but havn't decided yet.
If it was good enough for The Forth Bridge...
