boatmike
Think I know the answer to this but I will ask anyway. 2 Volvo TMD41a diesels. Both in good nick. Have just cleaned out the exhaust elbows and removed the dreaded damper thingies. Good flow of water now and minimal steam/smoke evident. Oil pressure great, temperatures OK but one engine makes 3800RPM at WOT the other only 3600RPM neither appear to be labouring and bottom of boat relatively clean. One idles at 650RPM the other at 720RPM. Also the Turbo boost on both is the same at 3600RPM but the one that will go to 3800 rises further when opened up that extra 200RPM (as you would expect) The cables are adjusted OK and both throttle levers on the fuel pump hit the stops. I see no reason not to simply adjust the stops to let the slower engines throttle open further and adjust the slow running stops to get idle in balance. Anyone disagree?
