Baggiwrinkle shop?
4 Feb 2003
UK
www.BrendanChandlerYachtDelivery.co.uk
I want to fit Baggiwrinkles or similar to the ends of my crosstrees.
How do I make them or where can I buy them or something else that will do the job?
http://hometown.aol.co.uk/brendanchandler/index.html<P ID="edit"><FONT SIZE=-1>Edited by BrendanChandler on 29/02/2004 18:19 (server time).</FONT></P>
Originally they were a seamans handiwork and made from old ropes ends collected together. Like many decorative and useful seaman items ......
<hr width=100% size=1>Nigel ...
<A target="_blank" HREF=http://www.qqbaltic.com/index.html>http://www.qqbaltic.com/index.html</A> For all those disbelievers ! /forums/images/icons/cool.gif
halcyon
20 Apr 2002
Cornwall
Thank you, you've just reminded me of another job still to do, replace baggiwrinkle.
Brian
jeanne
2 Apr 2002
Sanlucar de Guadiana, Espana
Baggywrinkle is so easy to make. Take a worn-out three strand rope, preferably terylene or nylon, as they have 'fluffy' ends, when you cut them up. Cut into 4 inch pieces. Don't seal the ends. Seperate into the three strands. Tension about 4 feet of light line between two fixed points. Take the first 4 inch strand, double it in the middle, put it around the light line, pass the two ends through the middle, and pull it tight. Do it again with the next 4 inch length, and push it tight up to the first. Do it all again, [and again, and again] until you have most of the four feet covered. You will end up with a thing like a hairy millipede, with legs two inches long. Seize the end of the light line to the standing rigging [where the sail touches it] and wrap it around in a tight spiral. Seize the lower end on to the standing rigging. If you prefer, self-amalgamating tape will do this well. Job done!
I seem to remember Eric Hiscock [my hero] remarking that it is often carried to excess, so don't overdo it. A short length of baggywrinkle every few feet up the standing rigging is as effective as a continous piece.
MainlySteam
24 Jul 2003
While I have no baggywrinkle (on the boat anyway!) I am always intrigued by the decriptions of its making. Consequently, I recall another good decription of how to do so by Mirelle which a search of his posts should turn up.
John
