MrB
One of the first things you check in preflight is if there is water in the tanks.Take it easy Bigp, you'll be getting the boat owners who also own planes on next, telling us how aviation fuel ages with time.
So many factors involved that there is no definite answer.
Garages use two types of storage tanks and these are the older steel types OR the newer plastic/composite type and this is crucial, tanks are installed and stay underground for decades and this is the first issue, steel tanks rust internally and externally as older types were placed in the ground and covered by clays or denser soils and this means they are sat in constant moisture, older steel tanks were riveted and newer ones are welded, riveted ones corrode around the joints and let water in and they all corrode internally and drop this crud into the fuel along with anything else which is introduced.
Tank breathers are the next issue, older types were open to the atmosphere and newer types are pressure differential operated to let air into, or out of the tank as required and when there is no pressure differential they close to reduce emissions, open types get all manner if insects and airborne debris into them as well as moist air during wetter periods, and in the hotter months this is fine silt like material which collects and sits at the bottom of the tanks, so fine debris and moisture accumulate in the tanks.
Cleaning is crucial and in many cases the tanks are never cleaned due to the cost and this debris accumulation simply builds up over time and it is pumped into the vehicles fuel tanks as they fill up, and due to more recent introductions to HSE legislation this cost rose many fold overnight and with margins so tight many operators cannot afford to do it and didn't.
Therefore you could end up with a site which has been developed and branded in the operators livery and looks very nice, but due to the expense, they leave the old tanks in which may be 50 years old and full of crap, they let a tank run low and it is sucking up mainly water and crap and you get issues with many vehicles filling from that tank and your insurers get hit with a big bill as retailers put more emphasis on visuals and branding than they do on tanks and pipework.
Perhaps I am being a little thick but was that Video taken in 2013 so the petrol was 2 yeas old or was that video taken recently ?
There was a case a few years ago where something went wrong with petrol supply for a few garages and thousands or drivers were left with broken cars.
What ever they did turned out that it destroyed O2 sensors on thousands of cars....somebody had a big bill to pay top get it fixed. it was all over the press at the time.
Blimey PF, you went from S of Turin up to St.Bernardino pass (i.e. 300Km or so, with the last 20 in a pretty steep climb), the warning only came on while going down after the pass, and you blame IT petrol?I filled up the W12 600 Hp Bentley last week south of Turin at a autosrada filling station all they had was 95 , I’d filled up with 95 previously in Antibes and within a hour decending ( mostly on the brakes so a lot of closed throttle= overfueling ?? ) the St Bernadino pass the CEL came on .
Besides, all in ONE hour? You must have used all of those 600hp and maybe an afterburner too, I reckon...
You paint a very black picture which simply cannot be true or we would see more vehicles broken down at the roads side. Your account is not bourn out by reality
Aren't you meaning Little St Bernard, maybe?Nah it’way less than 300 km Torino -St Bernardino
The one with the chuffing dog museum and about 7 dogs still there .Aren't you meaning Little St Bernard, maybe?
San Bernardino is the pass between Bellinzona and Splügen, with Milan in between, if you're coming from Turin...
Aha, ok.Great St Bernard , but on the IT side you sign it “ Bernardo “ Ok slight spelling but near enough ? Well for me
Links Valais to Torino
