LORDNELSON
I purchased this Merlin 28 in August 2008. The mast was un-stepped for the first time in my ownership last week. In order to remove the mast it was, of course, necessary to slacken off the rigging, this was done without problem until we reached the split back-stay; the rigging screws were undone to the point where they were almost apart but there was still a lot of tension in the back-stay and it appeared unwise to completely unscrew the rigging screws without precautions. We put a rolling hitch on the back-stay led it through a block to a winch and put tension on the rope and then undid the rigging screw - which parted very suddenly but was kept under control by the tensioned rope. When re-stepping the mast four days later the back stay was, of course, too short to connect with the rigging screw/deck fitting. We attached the main halyard to the back-stay via a block and winch and strained the mast back until it was possible to connect up the rigging screw. Is this normal for the Merlin 28? It seems a bit odd to have so much tension in the back-stay that one has to control it by ropes to undo it, when all rigging screws have been slackened off, but this is the first fractional rigged/bendy mast boat I have owned. When we had finished re-stepping the mast and screwed the rigging screws back to their original settings there was about 1.8% bend in the mast (the Merlin is, of course, a fractional rig with one set of swept spreaders, single aft lower shrouds and deck stepped). I would be most grateful for any comments.
