mattnj
I am trying to work out how its installed, and if it will fit on a tiller (in cockpit) with the main unit below decks?
Any pictures...
Any pictures...
Usually these are just Wuxi Hongba actuators which can be obtained more cheaply elsewhere - e.g. PC Nautic in the Netherlands.The only autopilot for a tiller steered boat with a ram and separate control head is the Raymarine Evolution, although it is possible to mate a Raymarine control to a Pelagic drive from the US.
I know you have posted this before - but who is prepared to buy 8? If there really was a market and it was that easy someone would have done it commercially. Realistically the market for pilots for tiller steered yachts is tiny and declining as almost no new boats that could use it have been built in the last 20 years. That explains also the lack of development in the current products unless like the controls on the Evolution they are shred with below deck pilots.Usually these are just Wuxi Hongba actuators which can be obtained more cheaply elsewhere - e.g. PC Nautic in the Netherlands.
Sone local chandlery needs to import them as they're less than £120 each (including shipping, VAT and import duty) if you buy a box of 8 from the factory and IMO they're at least as good as the Raymarine QO47 tiller drive, which seems for around £500.
I'd have thought you could use these with a B&G control unit.
Are you 100% sure on that...I've seen one directly attached to tiller bracket before wooden handle....with main unit below....it's clutched too...No. That is for a below decks installation onto a quadrant or a lever arm on the rudder stock. You do not have any exposed rudder stick to...
The motor cannot be outside. It is designed for use under deck. No reason why it should not drive a tiller but where do you mount the motor and take the thrust? Pretty sure they would be promoting it for tiller steered boats if it was suitable. This type of drive has been around for years and is useful on boats where it is not possible fit the more common linear drives and for cable steered power boats.Are you 100% sure on that...I've seen one directly attached to tiller bracket before wooden handle....with main unit below....it's clutched too...
The installation drawing shows it 200mm from post....so assuming I stick to that it can attach to tiller handle bit...can't it?
That is the point - it is in the marginal DIY realm rather than a commercial proposition.I'm sure you're right that the number of tiller-steered yachts is on a decline, but I wouldn't be surprised if a lot of the existing fleet are using Raymarine QO47s that are on their last legs.
My boat came with at least 3 broken spares. After I gave up trying to repair them I gave them to a neighbour who was delighted. He refused a Wx Hongba one because "I just like repairing things".
I bought a case of 8 from China and have sold 2 without advertising. I've had one other enquiry that I ignored (sorry, whoever you are) because I don't want to ship outside the EU.
I have 5 left (keeping one for myself) and buying them has now cost me less than an official Raymarine replacement. I really should post them on the Yacht Buts group.
It says... "The SD10 is a mechanical drive unit featuring built-in rudder feedback for sailboats between 25ft and 37ft. ...as part of an autopilot system. (Access to a quadrant or tiller is required)."The motor cannot be outside. It is designed for use under deck. No reason why it should not drive a tiller but where do you mount the motor and take the thrust? Pretty sure they would be promoting it for tiller steered boats if it was suitable. This type of drive has been around for years and is useful on boats where it is not possible fit the more common linear drives and for cable steered power boats.
Nice looking bit of kit but looks expensive to me. Drive unit is £1.3k, NAC2 ‘brain’ is £1k, and a controller and cabling will add a fair bit. Best part of £3k all in. What’s weird is that there is virtually nothing written on the web re this system, in terms of reviews and so on, which, I assume, is why the op is asking here. I’d want to be absolutely sure pre-purchase that it was a better system than the Raymarine Evo tiller pilot which is circa half the price.
Well, keep us posted. I’m very interested as I’m probably going to buy a Raymarine Evo for my tiller steered boat. I have an ST2000 which is ok but struggles in a blow.its B&G so its never going to be cheap!
Hopefully my "friend" in the trade can get me some good prices ...
Did you ever install this? I'm strongly considering the SD10 for my Corsair 970 Trimaran and have only found a small number of references to it online (mostly positive).I was thinking something like this...green being inside..
The main difference of the SD10 is the clutch, so its connected all the time....plus on the one I saw the tiller was basically kept up all the time, so you get the cockpit space back...
I’m also interested in this as an option, we already have b&g plotter which saves separate contolDid you ever install this? I'm strongly considering the SD10 for my Corsair 970 Trimaran and have only found a small number of references to it online (mostly positive).
You will still need an autopilot control head sensor and core in the same way as any other below decks installation, although of course it can be interfaced with your plotter. As noted in post#11 this is over £3k of kit - twice the price of the EV tiller pilot which has essentially the same software. Then the installation issues which mean it is impossible to do it on most boats. While the drive has been around for years under different names it has very limited applications. Rotary and ram drives cover most below decks installations.I’m also interested in this as an option, we already have b&g plotter which saves separate contol
