B & G Network Quad instuments
stewartkinsman
5 Jan 2009
Me - Scotland; Yacht - Turkey.
My Brookes & Gatehouse Quad instrument has suffered water damage and is partially malfunctioning. It is part of a set of three - Network Quad, Network Wind and Network Pilot. Can anyone tell me if I can simply replace the Quad with a Network Data instrument which I have located. Alternatively, does anyone have a spare Quad sitting on a shelf, or about to replace their Network system with something new. I am happy to pay a reasonable second-hand value to keep my system (which has performed well for many years) going for a while longer.
pvb,
Thanks for the quick reply. I have B & G printout which shows the Network Data instrument will display virtually everything, including speed and depth.
Yes, it will. But where's it going to get the speed and depth info from? You said you have Quad, Wind and Pilot instruments. Which one are your speed and depth sensors connected to?
Hi again pvb,
Speed and Depth are connected to the Network Quad. Depth is still working perfectly, as are the other instruments.
Obviously I misunderstood you when you said "Can anyone tell me if I can simply replace the Quad with a Network Data instrument which I have located". I thought you meant you were going to replace it.
'The Network DATA unit is a repeater of available networked
information supplied from other Network Instruments via the
system network.'
'It has no sensor interfaces as all data is passed to the unit via
the system network cables.'
The QUAD unit has two network connections plus two additional sockets to connect the sensors. The Data display only has the network connections.
The user manuals are available on the B&G website here http://www.bandg.com/Downloads/Manuals/
You need to have your QUAD repaired or find another.
NB not a QUAD Repeater. You need to be able to connect your sensors.
You may like to try John Holmes for a secondhand unit.
You could usefully speak to Tinley Electronics, they can repair most B+G stuff, even water damaged. They might have spare units too.
B&G Network Quad
Hello 2Tiswoz,
You mentioned "contact John Holmes for a secondhand unit"
Can you send me an addres, E-mail or something so I can contact John Holmes. I'm eager to find an replace unit as I mentioned in my post.
Greetings Henksailing
