D
Deleted User YDKXO
IPS experience- 25 knot— 10 l/Nm fully loaded 84 foot flybridge
Which boat?
Delta 88Which boat?
I think the comparison is reasonably fair for IPS versus shaft flybridge boat performance since all 3; the Azi, Ferretti and Delta are about the same unladen weight.Not sure an all carbon fibre boat is a fair comparison![]()
Yes sone hulls are more efficient at different speeds , which will have a knock on effect with the amount of Hp and thus fuel burn to push it along for a given speed .There’s got to be a difference. I come across huge wakes as some boats can only plough through the water on plane while others leave barely a ripple
If weight would be all it takes to make a fair comparison, some lorries are even heavier, and they burn much less fuel.I think the comparison is reasonably fair for IPS versus shaft flybridge boat performance since all 3; the Azi, Ferretti and Delta are about the same unladen weight.
BTW, you're actually talking of a 79 feet boat.84 foot flybridge
You may be correct but I believe the picture is of a Delta 54 hull. Only providing our experience with over 22,000NM in the past 4 years.If weight would be all it takes to make a fair comparison, some lorries are even heavier, and they burn much less fuel.
At Delta, they deliberately decided to go for a totally IPS-driven design of their hulls, rather than a sea-driven design as most other builders do - or at least some sort of compromise.
The result, which speaks for itself, is below.
Then again, maybe Delta was right and all others were wrong.
But they aren't the new kid on the block anymore, and if nobody copied their concept yet, there must be some reasons, I guess...
Agreed. Actual molded waterline length is 23.90m. Length from bow including swim platform is 25.84m or 84 feet.BTW, you're actually talking of a 79 feet boat.
Calling her an 84' (let alone an 88') doesn't make her any larger.
Just saying...
Correct, the pic was of a 54, but I think the design principles are similar throughout the whole range.You may be correct but I believe the picture is of a Delta 54 hull.
I'm confused - did you mean 64 footer?IPS experience- 25 knot— 10 l/Nm fully loaded 84 foot flybridge
84 feet LOA. Triple IPS 1200’s (900hp). As for IPS costing more in the end, you may be correct but we save E15,000 a year on fuel. Barnacles haven’t been an issue yet, but in full disclosure we lost a steering seal 2 months ago. Volvo covered on their extended warranty (5 years) but it was a P!TA.I'm confused - did you mean 64 footer?
I didn't think that Volvo made the bigger engines - let alone IPS of that size.
Anyway, have you seen what happens when barnacles get into an IPS drive?
I wouldn't be seen dead in an IPS boat so it doesn't matter how efficient they are.
IPS will always cost you more in the end.
Sorry, I have almost no experience on similar size traditional hull boat- only sea trials on calm days?Correct, the pic was of a 54, but I think the design principles are similar throughout the whole range.
Congratulations for the miles crunching, that's indeed impressive!
I guess you must have found some rough staff, occasionally.
Are you happy about how she handled that - possibly also compared to more traditional hulls of similar size?
