lw395
The solution of a light pickup buoy and letting the risers sink to the bottom works fine in shallowish water and limited tidal range, up to a certain size of chain. You can have a thick rope pendant for the last bit, like every other bit of mooring it needs to be checked from time to time. I suppose with a windlass, you could do this for a bigger boat and bigger chain etc.
I used Norfloat or Scanmarin 100 inch circumference buoys with a rod through the middle, plus a swivel on top. It was necessary to use such a big buoy, due to the weight of tackle favoured by our mooring contractor and the depth of water, about 10m at high tide. The swivel would pull up to about 6-12 inches from the stem roller.
The main problem with this was sailing schools lassoing the mooring when empty, destroying the buoy at £110 or more a time. The mooring was just too convenient in Portsmouth Harbour.
The best solution will vary from boat to boat and by location, as the chop and wind/tide will vary. I think it pays to sort your mooring out so that your boat is as steady as possible in the worst weather, less wear and tear all round.
