Would any one happen to know where I might obtain a new (or used) clip or clips that fit around the spoke of the wheel and connect to the Autohelm via 2 smaall allen screws?
Inventory is as follows--3x 10mm. 3x16mm. 2x19mm. 5x22mm and 6x25mm. that is the maximum depth measurement with the clip affixed to the wheel unit. You could always use a bit of packing or a spacer but I would not recomend trying to grind out material from the clip itself. Postage for a set of 3 $10 US. Clips F.O.C
