Autohelm GPS
Seven Spades
30 Aug 2003
Surrey
I have an Autohelm GPS at my nav table and I want to remove it to make space for a Nasa Meteoman. As far as I can see the GPS is superfluous as I have a Raymarine R70 chatrtplotter and it will display the same information. Am I missing something, do I need the GPS display, I had assumed that it was probably there before the chatrtplotter and now is redundant.
On the back of the GPS there are two three pin cables one male and one female so it gives the appearance that the GPS unit is "in line" can I just remove the unit and leave the cables tucked away neatly or do I need to join them together to complete the circuit?
Thanks.
What would you use for position if your plotter goes t1t5-up???
Keep the GPS as a back-up. I have a Navman plotter and an old AP-Philips mk6 GPS at the nav station, and an older AP-Philips Mk8 at the helm position. If all 3 give the same (or very near) lat/long, then that keeps me happy.
I also have a hand-bearing compass, and Yeoman/charts that are position updated every hour when on passage.
Belts and Braces. Overkill?? Maybe.
I disconnected it for about an hour and I didn't get a "No fix" message. If I link the in and out together will that cure the problem or is the display a compulsory part of the circuit?
