garvellachs
I'm trying to service my very old Autohelm 6000 linear drive. It predates SeaTalk and has the clutch with brushes, probably an original fit to our 1984 boat. It works OK most of the time, but it has become a bit notchy when in standby and I'd like to try and replace the balls in the re-circulating ball nut. However, I can't get the ball screw/nut out. I'm aware of how the ST6000 version disassembles, but this older version is different. There's a (ball?) bearing in the recess. There was a washer on top and a circlip holding that in place, now removed. I'd expect the shaft to slide out but it doesn't. Tapping it doesn't produce any movement either way either. Anyone done this before maybe?
(And yes it's old and past it, but the boat only has 2000 engine hours and a new linear drive is megabucks.)
