Wing Mark
The Moth is actually a very good example of fixating on e arbitrary constraint, length as measured in a particular way.I should like to see you explain to me how a Rustler 36, with a reverse raked stern and outboard rudder, increases her dynamic DWL when heeled.
She is not an IOR design either, for that matter.
I too think that, as racing boats, contemporary shapes are much superior to those built under IOR rule.
The extreme interpretation of the IOR rule essentially led to what amounted to a double ender with extremely steep buttock lines that had a tendency to suck up the stern wave, effectively preventing above displacement speeds. To provide stability to these very light boats, beam was added amidships. As speed increases, the developing amidships wave through would severely diminish such stability, which in turn promoted the famous death roll behavior when running hard under spinnaker.
As usual, racing success also bred a whole slew of cruising boats, including motorsailer/deckhouse designs, that mimicked typical IOR features.
In regards as to hull shapes, apart from foiling designs and even that is highly debatable, there is not much new under the sun and much of what is now heralded as cutting edge contemporary can be found in Great Lakes scows, 19 century sand baggers or skimming dishes, including twin rudders, asymmetric twin dagger boards, wide sterns, etc.
The biggest and most significant progress has been made in the application of new materials that now allow us to save (significant) weight while assuring such shapes stay stuck together, mostly anyway.
If you fancy to sail a boat with minimum rule restraints, get a Moth dinghy. Let us know how your cruising goes.
There is a strong tendency on this forum to compare apples and oranges. When someone points out that a 30' overall cruising boat with basic modcoms, as we have now come to expect, the power generating and storing infrastructure to support this, an engine to reach hull speed in full trim and adverse conditions, proper ground tackle to stay in place once you arrive and a set of bicycles for shore excursions, is not likely to plane, then some wag will post a pic of a 60' carbon sled that features a washer/dryer to prove that contemporary design is not only better, but faster.
Before they went foiling. the notional 'hull length' became a joke, as the real length was increased by a rudder gantry.
Now they have a prodder sticking out the front to hang the wand, or ride height sensor, from.
It's notionally an 11ft boat, but you could build a better boat for the same money if you dumped the 11ft restraint not including this and that.
Likewise various skiffs are longer than their headline 'length' with rudder gantries at the blunt end and bowsprit brackets at the sharp end. You won't get a '16ft' skiff in a 17ft shed.
Rustler's design was probably constrained by what they thought their buyers wanted the boat to look like.
If people wanted the fastest boat for 36' on deck, then they'd have a plumb bow and transom.
