DavidJ
Reguarding you both as the fountains of all knowledge, I have an interesting problem. (Happy to hear from other fountains of course!)
I have an S37 fitted with KAD43's
I had an intermittent problem from new which was that the turbo on one side sometimes refused to come in (at 1600RPM) eventually it totally refused and I identified the problem (by swapping parts) as the little electronic box on the top of the engine. Volvo replaced it under guarentee.
On examining the box a transistor had burned out.
The problem went away but I believe now, 3 years later, that it is slowly returning. It seems (I think?) more of a problem under heavier load ie dirty bottom or lots of people on board.
My question (eventually) is "is this a problem that you have come across before and can there be something external to the electronic box causing the problem.
ta
ta
