Attaching Jib sheets
Spyro
18 Jan 2003
Clyde
I'm replacing my Jib sheets. I have usually tied them on with bowlines and tape the ends to ease them going around the shrouds but I have seen some that have been attached as one continuous line as seen in the pics. I see it as an easier method of attaching and unattaching and thought they might go around the shrouds easier. Anyone do it like this and are there any disadvantages?
Thought about this one
Seen this one but thought it might slip.
Iain,
I use a continuous line, but I whipped a loop in the middle to attach to the clew using a soft shackle.
It makes life a lot easier if I want to use the same sheets for the storm sail or even the stay sail on the inner forestay.
Your second will slip
Soft shackle and a soft eye in the end of each sheet, used this for several years, does not snag on shrouds or baby stay. Easy to remove when necessary.
++++1
Having been hit by a snapshackle/J clip, ouch! Such solutions are best consigned to the dark ages along with wire sheets and guys, children down mines, burning witches etc.
I've never seen the first one before, I've just made one using a bit of spare rope round a dowel. It seems to want to loosen over a sequence of load reversals as strain is put alternately on each side, as when tacking etc.
I've used the second one which I know as a cow hitch. It has never slipped for me but it does tend to crush the sailcloth & stitching round the clew fitting as it tightens up with use.
I also wondered about them wearing as they tighten and release. The soft eye seems popular. I suppose nothing to loose by tryin either method. I could easily cut in the middle and go back to bowlines.
I splice eyes into the clew end of both sheets, secure them to the clew with a dyneema soft shackle, nothing to catch on the shrouds, very boat friendly.
R
Lumps of metal like that attached to the clew will kill you if you have to get onto the foredeck and deal with a flogging foresail.
Iain,
+1 Also soft shackle easier to open when things are interesting, no pin to lose or lump of metal to beat you about the parts.
