MattS
My galley sink has been leaking into the cupboard for months, and I finally worked out that it was leaking from where the drain hose was attached to the outlet nozzle.
Ah, a simple case of tightening the jubilee clip, I thought.
Seems that there's no way for the jubilee clip to actually get a tight seal around the hose and nozzle, because the nozzle is smooth and tapered meaning that as you tighten the jubilee clip it just slides the hose down the taper, never getting tight.
Besides the fact that I haven't easily found a replacement outlet fitting, I'd quite like to DIY solve this... I tried scoring a ring around the nozzle to give the jubilee clip something to grip to, but no luck there...
Any ideas on how to get a good tight seal between the hose and the nozzle??
