AT last a clear explanation of how we get 2 tides per day !
Oh dear - surely someone as clever as Brian Cox knows there is no such force as "centrifugal force".
And how does he explain those places (Gulf of Mexico or Vietnam) where there is only one tide per day?
Maybe that's down to those 'lazy Mexicans'...
And I s'pose explaining the 240-odd Harmonic Constants and 'resonant chambers' would take up too much broadcast time. So, two beach pebbles.... on an exotic beach.
Is it accurate (apart from the centrifugal force terminology)? Does the bulge on 'the other side' occur because it is further from the gravitational pull of the moon, and the difference is significant? Or is it that when you resolve the forces, the component trying to move the sea sideways at that point is virtually non-exisistant?
The reason the clip is brilliant is that it is simple and comprehensible to normal people. Whilst it would be more correct to refer to the reaction to centrepetal acceleration required to maintain a fixed radius from the centre of a rotating object I suspect this would not be nearly as comprehensible to most people.
I think its because the earth is swinging around a point between the earth and moon ( the centre of mass of the earth moon system) and the sea on the far side is at a greater radius from this point and therefore the water is being flung outwards more than that which is nearer the centre of rotation
You what? Centripetal is a direction - the opposite being, of course, centrifugal. Accelerations aren't the things that are generally considered to have reactions, forces however do, per Newton III.
There is not really enough information in the video to understand his explanation but I am almost sure he is wrong.
One of the reasons no scientist would talk about centrifugal force is that it doesn't exist - so it tends to be introduced to gloss over a lack of understanding of the forces that are actually acting on a body.
I think it's a crappy explanation, if not bollocks. The inverse square law is enough to explain the tides.
You could argue that the two explanations are equivalent. If gravity is the centripetal force and diminishes as the square of the distance, then it's less on the far side of the moon. If you are willing to regard diminution of centripetal force as an increase in (non-existent) centrifugal force then you might give some credit to his half-assed explanation.
However, why would you invoke two concepts to explain something that is simple to explain with one? Bad science.
...but of course gravity (g) is not a force.
Newtons Law is a good approximation and allows interpretation of gravity as a force. By the same token you can argue that, within the frame of reference of the spinning, centrifugal force exists. My primary complaint about the weak geek explanation is that it invokes two different models where only one is required, and so creates a complex explanation where a simple one would have done just fine.
:) Oh the conceit.
It might actually be better to talk of Centrifugal effect as with the Coriolis effect. One might well use Gravitational effect as well as they are all fictitious forces.
Brian Cox is attempting to show something less immediately obvious which is the very well understood classical idea of Barycentre. In my opinion this is much better demonstrated by an animation graphic. Google will help :)
:) Oh the conceit.
No - you are missing my point. It is not just about terminology it is about the genuine forces involved.
I think Cox is wrong in his explanation and his invocation of a non-existent force is hiding the error in his theory. He needs to be more explicit about what is rotating about what and how fast - there are too many different rotations involved
