ChromeDome
Fujinon and Canon models with stabilization are brilliant for marine use.
Not cheap, but outstanding.
Agree. I have the Fujinon stabilised bins and they are superb. They let more light in than Steiners IMHO (repeated side by side tests in the dark at Iken).Fujinon and Canon models with stabilization are brilliant for marine use.
When we sailed back through Denmark with our then new boat many years ago we had to work our way through narrow sounds marked by their funny little stick buoys, and it was absolutely necessary to distinguish port and starboard. In still water but with a lot of wind none of us could reliably judge the channels with good quality 7x50s and 8x24s. It was this experience that led me to buy my Canon 10x40s with IS, and they have given me much pleasure ever since, both on the boat and bird-watching. The only alternative from Monk Optics at the time was a very bulky Fujinon pair that stabilised in more than one axis, but they were three times the price and unnecessary for me. I haven’t needed to look at the current offerings.Agree. I have the Fujinon stabilised bins and they are superb. They let more light in than Steiners IMHO (repeated side by side tests in the dark at Iken).
Not only in Denmark, the so called side markers...funny little stick buoys..
Focus-free is fine for those with good uncorrected eyesight, or who use contact lenses. But for those who use glasses, it may not be a good solution unless the eye-relief of the binoculars allows for the use of glasses and, to coin a phrase, your mileage will quite definitely vary! Otherwise, binoculars with focussing allow for correction of vision (within limits) and for differential correction between the eyes. It does, of course also mean that other people struggle to use "your" pair of binoculars! Focus-free also imposes limitations on the optics of the binoculars; basically, it's a fixed focus system designed to have a wide depth of field. Greater depth of field results from a smaller aperture, so the light-gathering power of focus-free systems may be constrained.I'd always go for focus free as you can be much quicker, especially with gloves on, to see what you are looking at clearly. I've had a pair of budget ones, glued back together once and 25 yrs old, now more bird watching than sailing. These BARSKA focus free are very similar, mine were 7 x not 10 7 Best Automatic Focusing Binoculars | Reviews & Buying Guide About £30 or £40
Thanks - I was going by my (limited!) knowledge of how it works for photography! But Optics is not my specialty; A-level physics is as far as I went with it. Your explanation is well beyond my knowledge of lens systems.Atlantic Pilot I normally agree with you, but not on your reasoning on ’focus free’ binoculars is not determined by smaller aperture (neither objective or ocular) it is that the focus of the binoculars is set at the ‘hyper focal point’ which gives the maximum depth of field, but results in the ’minimum object distance’ being at a greater distance.
John,When we sailed back through Denmark with our then new boat many years ago we had to work our way through narrow sounds marked by their funny little stick buoys, and it was absolutely necessary to distinguish port and starboard. In still water but with a lot of wind none of us could reliably judge the channels with good quality 7x50s and 8x24s. It was this experience that led me to buy my Canon 10x40s with IS, and they have given me much pleasure ever since, both on the boat and bird-watching. The only alternative from Monk Optics at the time was a very bulky Fujinon pair that stabilised in more than one axis, but they were three times the price and unnecessary for me. I haven’t needed to look at the current offerings.
However, I would not recommend that people immediately fork out for IS binoculars without first deciding if they really need them and trying them out. For some reason that I don‘t really understand, there are those that don’t ’get’ the point of IS when they try them, and the extra money would obviously be wasted on them. They are reasonably robust, but expensive and not waterproof, so it is well worth having a pair of 7x50s on board as well, especially for use at dusk.
You are mistaken if you think that A level physics is of any use in the real world. All the time I spent trying to master things like Wheatstone bridges was of no use whatever when faced with my boat’s electrical circuits.Thanks - I was going by my (limited!) knowledge of how it works for photography! But Optics is not my specialty; A-level physics is as far as I went with it. Your explanation is well beyond my knowledge of lens systems.
Yes - there's a big gap between theory and practice in that sort of area.You are mistaken if you think that A level physics is of any use in the real world. All the time I spent trying to master things like Wheatstone bridges was of no use whatever when faced with my boat’s electrical circuits.
The Wheatstone bridge is a remarkably simple but nonetheless elegant, device. It’s more that 150 years or so of hardware development have made left it behind. As a retired experimental physicist I find the discipline applicable in many different areas ….navigation, sail trim, home heating, weather forecasting, hi fi, , binoculars, .. . .Yes - there's a big gap between theory and practice in that sort of area.
Yet high school physics allows simple mechanical advantage loads to be understood and provides understanding for basic, electrical design and problem solving. Personally, it was not wasted on me. I once raced a yacht with a Wheatstone bridge charging adjuster.
I find that my physical knowledge greatly helps me to understand how systems work; I can usually calculate things like loads and currents in circuits quite well using basics like Ohm's Law and Kirchoff 's rules (but I'll leave things like an infinite grid of 1 ohm resistors to others!). Of course, Newton's laws are encountered every day, and vector maths is an integral part of marine navigation.The Wheatstone bridge is a remarkably simple but nonetheless elegant, device. It’s more that 150 years or so of hardware development have made left it behind. As a retired experimental physicist I find the discipline applicable in many different areas ….navigation, sail trim, home heating, weather forecasting, hi fi, , binoculars, .. . .
Read and green, different top signs to help identification in less than perfect light conditions
Some places may offer variants - this one showing why they're called brooms also:
Seen in Germany, of course not meant for long distance identification
Oh - so she'd be stuck to the other end?That last photo suggests you've found my mother in law's crash site.
