boomerangben
Pye_end,
As I said earlier, the buoyancy force is the resultant of the all the fluid pressures surrounding an object acting on the wetted area. I demonstrated earlier that for a rectangular box shaped vessel, the buoyancy force can be easiliy determined mathematically. It is more complicated for a curved structure, but it works just the same. What Archidemes noticed was that when you do this calculation, you end up finding that the mass of water displaced by a shape is equivalent to the up thrust (buoyancy force) exerted on the shape, ie is a special case and can be used as a short cut.
The density of an object is a property, in the same way that its colour is. It is the same whether the object is underwater, in air or in outer space. No force is generated by a density.
If Naval architects used relative density, can you imagine how hard it would be to calculate the density of that part of the ship which is below the water line? In practice, Naval Architects only use the density of the water their creation is floating in. Only one density, therefore they cannot use relative densities. They don't need to , because of Archimedes Eureka moment.
