simonfraser
http://aqualarm.net/10333-barbed-water-flow-detector-for1-in-hose-size-p-62.html
The instructions say install with the flow horizontal, that can be done, but
From the supplier in the USA:
The sensor needs to be perpendicular to the ground. It can be angled slightly to one side or the other . If it is angled a lot or parallel to the ground, you may experience unsatisfactory results. Only installation and test will tell . When the detector is angled, gravity starts affecting the paddle.
Any one has the sensor to the side, or at least significantly away from the vertical ?
