Feneris
I'm hoping someone can advise me on the overhaul of a Penta raw water pump on an AQ170C. There was dripping from the tell-tale drip hole in the waterpump. A previous owner had a solution for this - wrap a bit of cloth round it and hold in place with a cable tie... drip solved!!
There was also a spare, old water pump in the boat when I got her so I had 2 broken pumps to compare.
It's dripping because the water seal is leaking. The seal is leaking because the seal has worn into the shaft, and the wear is 'rough'. Also, the bushings that act as bearings are worn, along with wear on the shaft, so the shaft has play in it(On both pumps).
Correct option - buy a full pump service kit from Tricket or Keypart (bit more pricy), which gives replacement bushings, shaft, seals. Costs £90 - £105.
Problem I've got is how to extract the bush from the front cover plate. Has anyone done this??
Other idea is to lathe the central shaft down very slightly, from 16mm to maybe 15.88, buy an 5/8ths (15.88mm) bush and lathe down the outside of the bush to fit the pump. This will take a few hours on the lathe, but would save about £70. I've got a spare pump to 'play with'. I would still have to get the bush out of the front plate thou.
What are your thoughts?? Cheers, F
