anyone got a small lathe?
mattnj
26 Jul 2007
www.red-data.co.uk
anyone fancy making me up a small ish part for some beer tokens?
havent measured it up but would be a 40mm diameter ish boss with a 10mm hole through, 40mm long, and turned down to a "pipe" fitting size on one end....in mild steel would be fine...
would be most appreciated and happy to paypal some cash over to a helpful PBO person...
fergie_mac66
28 Jun 2009
south yorks
is that wood or metal lathe
penfold
25 Aug 2003
On the Clyde
How thick is the flange? Does it have to be out of solid; I have scrap to fabricate/weld that, but not turn from solid(plus it would be a ballache making all that into swarf).
Avocet
3 Jun 2001
Cumbria
I agree - lot of waste on that if machined from solid. It's not that mild steel is expensive, it's just the machining time to (in esscence) make a fair bit of scrap!
Anyway, I have a lathe, so PM me if you're not already sorted.
mattnj
26 Jul 2007
www.red-data.co.uk
guys come along....hardly a lot of turning now is it (unless on a watch makers lathe!)
seriously thanks for the offers, the fabricated item would be bent, needs machining really as all needs to be true....(well the back flange does need to be)
I have come up with a plan to make up something out of copper plumbing fittings (and come copper plate) and solder it together, will come back an PM you if i get stuck, cheers!
Andrew_Fanner
13 Mar 2002
ked into poverty by children
Just looking at it the fittings used in kitchens to hold the ends of support legs for eg a breakfast bar would make a basis for the flange section. What is it for? With my used to be model engineer's hat on its the sort of part I'd expect to machine from a casting or fabricate from a sawn blank for the large diameter flange part and turn up the spigot part as a seperate job fisxed to the flange in whatever manner seemed suitable.
Mild steel does not sound expecially boaty as a material:)
mattnj
26 Jul 2007
www.red-data.co.uk
eh? a casting for 1 piece? dont think so....all this talk of fabricating, then machining, i use to run a machine shop with my dad, trust me for a 1off, for what i want turning that out of a blank would the the easiest (assuming you had a decent lathe) would only take 10mins...no way you could get a casting or fabricate 2 bits, weld and machine after in that time....did it for a living for 10years....
Anyway, thanks for the interest, the project it a 12v micro generator based on a Honda GX25, 25cc 4 stroke (1hp) running a lightweight (motorsport) alternator (40amps)
Whole thing is about 7kg....will post up the details when its running, almost done!
It is currently air cooled and noisy ish....all down to the exhaust...
I am experimenting with a water cooled system with an exhaust elbow so i can put it in a box and make it super silent...but as i said in earlier post, first efforts will come from some copper plumbing kit...
penfold
25 Aug 2003
On the Clyde
I wasn't proposing that, I simply don't have any steel 40mm in diameter. I would turn up the 14mm bar, then weld on a roughly circular piece of 1/2" plate and turn it square. Final op would be boring the hole.
Editted to added; seeing the above it sounds interesting. Do keep us informed! My lathe is a Viceroy 5x24; not a watchmakers' but not really the tool for making blue swarf with either.
Andrew_Fanner
13 Mar 2002
I appreciate that a casting for a one off is hardly viable:) Having said that, I had in mind adapting something from another purpose, the drawing is very reminiscent of boiler flange fittings used by big steam trains and there is a thriving cottage industry in those, indeed some of the bigger railways have limited casting facilities.
I appreciate your experience, but tha 10 mins is on a big lathe with plenty of stock to hand and hang the value of the swarf! I was under the impression you were looking for what could be knocked up from stuff found about the home workshop/garage and bunged in the ML7, indeed I expect even a little Unimat would make the thing with a little time to think it through and wise choice of stock sizes.
Interested in the project, do keep us posted n it.
