Baggywrinkle
Thinking of installing a Schenker Zen watermaker ... anyone got one and what do you think of it?
Ours makes 240L/hr in the Caribbean. Where do you have yours located that you have to listen to it? Mine is in an acoustically enclosed engine room so not a big noise makers. Its quieter than the generator in it's acoustic enclosure within the engine room!I’ve had one for 3 years as a half the year liveaboard. Very happy. Reliable, very quiet, very energy efficient. I’ve still got my old high output 230v unit pickled and I hope in a working condition. Most components have been rebuilt or replaced, so it’s ready to go as a backup, but even with my best efforts it was so unreliable at 19 years of age that I got sick of it and bought the new Schenker. If I hadn’t got the old one as a backup, I’d get two Schenker 30s. If you go a/c, get a big output unit so you have to listen to it less.
Mine is also in an acoustically insulated engine room. It's about the same noise as the genset, also in it's own secondary shield. A 2.0kW motor and a standard Cat pressure pump. Maybe your noise tolerance is less. The only noise I like is ACDC and not the electrical one.Ours makes 240L/hr in the Caribbean. Where do you have yours located that you have to listen to it? Mine is in an acoustically enclosed engine room so not a big noise makers. Its quieter than the generator in it's acoustic enclosure within the engine room!
Either way, it's really not noisy and the run time is so low for our daily needs it's not invasive. We don't have to run it for hours like our old 12v watermaker and power is no problemMine is also in an acoustically insulated engine room. It's about the same noise as the genset, also in it's own secondary shield. A 2.0kW motor and a standard Cat pressure pump. Maybe your noise tolerance is less. The only noise I like is ACDC and not the electrical one.
I completely disagree.Either way, it's really not noisy …
On your boatI completely disagree.
Obviously. I responded to your statement that my watermaker was not noisy by saying I disagreed with you. It is, even through my 2” of multi density layered acoustic insulation plus heavy plywood..............
On your boat
Just like you would never have a generator or engine in your saloon. You install them appropriately such that noise is not an issue. The great thing with them is super low run time compared to energy recovery watermakers. If you don't have a high output AC watermaker and you are runnjng that for many hours then you have the wrong AC watermakerObviously. I responded to your statement that my watermaker was not noisy by saying I disagreed with you. It is, even through my 2” of multi density layered acoustic insulation plus heavy plywood.
Objectively, AC watermakers make a racket. You would never have one in your saloon if you could avoid it without sound proofing.
It is possible to soundproof almost any noise by deploying enough resources. The real issues are then more about to what degree you are able to do that and about how much time and money to invest, if any. Or if you would prefer an energy recovery unit.
