lampshuk
My 1988 Moody's throttle assembly has become stuck in gear.
I disconnected it from its mount and the gearbox & cable are fine.
The "disengage" pin springs back when depressed (but possibly not far enough)
The levers all work correctly and there is no problem with the clips holding the cable to the main assembly.
I've cracked open the control case and carefully dismantled the unit down to the main control "pillar" and attached flange.
It appears to me (see attached photo) that the retaining pin ought to engage in the slot in the flange, but it doesn't, and the pillar/flange assembly seems to be fused.
Does anyone know if it's supposed to look like this? And if not, how to rotate the pillar to bring the pin in line with the slot?
As always, any advice much appreciated!
