cskaplan
My temperature gauge has read too high since I got the boat. The Volvo thermostat is set at 180, my gauge typeically would read 200 - 210. I assumed I was running hot and checked the impeller, water flow through the exhaust, replaced the thermostat, flushed and removed the heat exchanger core (but it was fine). I got an infared thermometer and checked around the thermostate housing, and apparently I was never running hot at all. I get readings of around 170 - 176 anywhere I check on the engine. Now, after too much expense time and frustration I believe my guauge is incorrect. I replaced the sensor to no avail. I shorted the two wires going to the gauge and the gauge goes full scale. I also ohmed out the wires and they are good.
I can only think that the gauge is bad and not reading correctly. is there a way to calibrate the gague? I don't have a PCB, it's a simple dash board. I see a small screw on the gauge face but I think it just holds the gauge face in place. I may replace the gauge entirely if I can find a replacement that will fit in the dash board. Has anyone else had experience with this? Thanks in advance..
