Any Tomos outboard owners out there?
If you can accurately measure the diameter (well, as close as you can) just obtain a knitting needle of the same diameter and cut off pieces to the required length. That is what I did when I had a Tomos 4,8 and that is also the source of shear pins for my old Yamaha 2. Cheap & Cheerful. :)
Ditto- I scrounged some stick welding rods and used the angle grinder to make lots.. Stick it in your boot with the prop off, poll up to your local engineering firm at lunch time and smile...
Brass and alloy rod is available on ebay.
Knitting needle is a cunning thought for odd sizes though!
