RichardS
N/A
Me too and for much longer than 12 years - this comes as quite a surprise - where can we see this advise from Yanmar ?
See post #10 for Yanmar bulletin.
Richard
My last boat had a 2GM20FW Yanmar (shaft & P bracket) and the manual said to lock the prop in reverse. Current boat with a Volvo says let it spin (saildrive) They were both correct for the health of their respective transmissions but as to drag (here we go again!) I believe that pulling a locked prop through the water, once a "cavitation-like" situation is achieved, causes less drag than a freewheeling one.I have been sailing with my GM gearbox in reverse for the past 12 years and this is the first time I have ever heard that it should not be done. Forward gear does nothing, prop still revolves. I start the engine with gear still in reverse, then shift into neutral.
The simple answer to all this is to get a folding prop ! Apart from the initial investment, there are no downsides.
Ah! Good to hear that. The Autoprop was on my wish list should my Maxprop go toes up. It seems such a neat design solution.I won't argue, although I have read plenty of adverse comments about folding props going astern. However, if I stop my Autoprop by selecting reverse, then go back to neutral, it will resume rotating.
Agree. Before fitting my FlexoFold 2 blade we carried out a lot of back to back tests (for another project) with a variety of different designs of props against the standard 2 blade fixed (on a saildrive). Apart from the slight lag when the blades open in reverse, performance in all other respects (speed, stopping distance, bollard pull) was the same for the fixed or the folder. Blade size and shape has a big influence on performance.No complaints at all with ours, although our massive Volvo three-bladed curvy thing is a far cry from the old tiny two-blade egg-whisks.
