Very good. Came with the boat haven’t found a use for them in 2.5 years. Off they go!You tie them on to things if you want to pull or apply force. The hard bits at the end help with attaching them to whatever you want to pull. The rolly bits allow you to multiply force or change the direction of force with low friction.
If you already have all the bits of string you desire do away with them. They tend to gather in lockers when you are not looking
That’s what I was leaning towards. I have guys and sheets so not sure if they are necessary? I did see Pip Hare’s video where she says pull the BH/tweekers on before a gybe. So maybe keep them on board?Barber haulers for the spinny?
Let’s hope notYep, if you haven't used them before, unlikely you will test them out on the RTIR. Although a good rule of thumb is that anything useless you remove from the boat will become the most useful bit of kit ever devised as soon as you are out at sea.
Thanks Nìgel think it should go outside guard wires.Looks OK to me, I have a single cam cleat block mounted at the tow rail about midships, 8mm line through it and I use a small snatch block over the gennaker sheet for sailing deeper angles, reduces the clew bouncing around.
By the way, what diameter of Selden bow sprit is that, and the make of the stanchion mounts?
Edit, bit of googling and they look like Forespar pole chocks. Only go up to 3.5 inch, I have a 99mm bowsprit, could not find any suitable stanchion chocks and ended up with a mate turning up a couple of HDPE rings, to which I fitted stanchion brackets
bowsprit is 75mm diameter and the clamps are Forespar. The angle of the mounting on the pulpit means it doesn’t quite fit but a bit of shock cord secures.
Well actually barbner haulers on jib sheets can be left attached ie sheet runs through the pulley or ring when not in use. Sheets are not hindered by barber hauler being attached. Having said that I carry barber haulers for jib wen racing but in reality do not bother to use them. Just lazy and reaching legs too short. ol'willAs Barber hauls yours would really need be attached in anticipation - or change the blocks to snatch blocks (which are commonly not very cheap).
For our spin sheets we would attach the barber hauls in advance. For Jenny trimming we would use snatch blocks, but we might use 2 sheets - it all depends on your kit (winches) and imagination.
Jonathan
If you don't rig barber hauls in advance you will never use them, too much hassle as you need slack in the sheet(s) to rig the barber hauls. So.....unless you are seriously going to use them - put them back in the bag and forget them.
We would take all our sails off and roll them, with the sheets, after each weekend of racing, the spinnaker would be neatly bagged and the sheets removed from the deck, coiled and stored. The barber hauls for the spinnaker we ran through blocks on the toe rails, the tail led aft - so they could be controlled when in use from the cockpit (you don't want crew dancing around on the foredeck to trim barber hauls).Well actually barbner haulers on jib sheets can be left attached ie sheet runs through the pulley or ring when not in use. Sheets are not hindered by barber hauler being attached. Having said that I carry barber haulers for jib wen racing but in reality do not bother to use them. Just lazy and reaching legs too short. ol'will
