Any favourite 2 pin, inline, waterproof connnectors?
NealB
19 Feb 2006
Burnham on Crouch
If you want to use it as a deck fitting, they are ok but I prefer a S/S Swan neck deck fitting with a connection box below deck.
Sorry....
the deck end is sorted (a gland, with below deck connection: similar to your suggestion).
I'm thinking about the connection at the top of the mast.
A twin- cored wire is poking through the mast, and needs to be connected to the two wires from the tricolour.
captainboo
11 Dec 2008
Near Glasgow
I used a 2 pin AMP Superseal connector (search on ebay - quite cheap). Will be waterproof on its own but can be wrapped in self fusing silicone tape for extra protection. You can then remove the light at any time without cutting the cable.
David2452
6 Jun 2001
London & Fambridge
+1 I keep lots of them up to 8 bay and they are easy to get a good water resistant (not proof) demountable connection, a bit larger than I would like for some applications but very good in every other respect and blilliant for heater harnesses. Favourite is Deutch, but they require expensive dedicated crimp tools.
prv
29 Nov 2009
Southampton
In the same situation I would solder (properly done crimps also very acceptable) and then cover with adhesive heatshrink. But if you want a removable connector, mine is another vote for Superseal. I give them a dose of Contralube too.
typhoonNige
29 Aug 2006
Lymington
I use Dri-plugs for our 100w solar panels so that they can be easily removed. I've put Contralube on them from new and they are still in good order after 16 months.
N.B. the socket is designed for bulkhead mounting
lw395
16 May 2007
These work well on my motorbike.
I would think about ensuring the join is not under tension or vibration, cable tie it to take the strain off the connector.
