antifreeze
dj43
20 May 2009
cambridge/Isle of Wight
Hi All
just had a quote for volvo antifreeze,I no its for a boat so going to cost more,but is it any different or better than what you put in your car,be interested to no what others use.
sarabande
6 May 2005
some anti-freezes are quite unkind to the marine environment when you flush the engine into the sea.
Anything made with ethylene glycol is nasty. Propylene glycol is less hazardous.
Please make sure there is none left around to attract cats, which like to lick up and then die horribly over several days.
VicS
13 Jul 2002
It is possible to get propylene glycol based antifreeze, easily in the US, but all the common ones in the UK are ethylene glycol.
There are two different inhibitor systems. the conventional low silicate system and the long life "organic acid technology" (OAT) systems. The two must not be mixed although it is possible to buy a Universal top up.
AFAIK the Volvo stuff is a conventional low silicate type with no advantage over what you can buy from a motor factors or even Halfords
markcw
30 Jun 2011
Bridgwater, Somerset
www.youtube.com
I didnt know that about cats and antifreeze, well theres a bowl out tonight for the b!"£$%^d cat :D that we have near us that is spraying all around our car port, boat trailer and boat and decking and our sofa on decked area. weve even had it on our recently washed cloths.
Every morning we get up go out the front door and:mad::mad: what a stink dame animals, may be i give it some food just to make it thursty.:D:D
If youve ever sufferd with this smell you will know what is like, p!"£$%g on my boat never again:mad::mad:
dragoon
13 Oct 2003
Gosport
I hope that's a joke....
RIN
2 Mar 2003
West Midlands
Hi All
Its the same Antifreeze that goes in a volvo truck. You can get it from your local volvo truck centre. Part no 1089240 £2.39 per litre last year (concentrate)
You can also get VDS2/3 oil 1161975 £46 for 20 litres Plus Vat of course
DAKA
7 Jan 2005
Nomadic
I thought some antifreeze was unsuitable for aluminium engines .
Do any boats have alumina bits in their cooling systems ?
PlanB
5 Sep 2004
We were trying to work out whether we could flush our fresh water system with Radflush and decided to read the manual (TAMD71Bs) where it said in big letters do not flush with chemicals due to aluminium bits!
VicS
13 Jul 2002
The single component "Speedflush" may not be suitable but the 2 component "Radflush 2 Part" is stated to be suitable for all engines
Assassin
23 Jun 2010
Daka:
Anti-freeze has a main purpose of preventing internal corrosion in an engine, its secondary function is preventing feeezing of the cooling system. All engines have dissimilar metals inside them and its this, along with electrical current passing through them which causes corrosion internally.
RIN
2 Mar 2003
West Midlands
Thanks for replys
Think I will stick with the volvo antifreeze,but use there commercial one,thanks for the tip Rin,now to find a supplier,
put your postcode here http://www.volvotrucks.com/trucks/uk-market/en-gb/dealers/Pages/dealer_locator.aspx
Last year I was asked to take a container to put the antifreeze in as the centre I went to had a reservoir of the antifreeze. Call them before you go to check as your truck centre might sell it in 5L containers part no 1089238
Grunter
23 Oct 2011
Having lost Two cats recently to someone who thought that his vegetable patch was more important than the lives of the kids pets, I have learned quite a bit about it and I can tell you now, if you are THAT bothered get an ultrasonic repelling device for a couple of quid! When a cat or dog ingests A/F it gets into the system within 20 mins, at that point they go blind and appear drunk. This is just about the time they make it back home which causes great upset to the owners, especially kids. This will last about 3 or 4 hours where they appear to make a recovery, their sight returns and they will eat and drink again. This is because the internal organs have dealt with the initial poisioning. However the damage is done and the internal organs will all now fail, Fitting will start and continue on and off for a few hours before they let out their final cry. The only way to save your pet from death is to give vodka, (neutralises the A/F alcohol) but, it should be intravenous and needs to be done ASAP. normally only effective if you actually see the pet drink the A/F. We were told to syringe vodka every hour, but being blind and not being in the mood to be handled I got bitten quite badly, not the playful nip but up to the gums and thrashing around caused some damage, enough that I could not move my hand properly for a week.
So take that thought and remove it from your mind... its certainly no joke!
gpssti4
28 Sep 2011
Deepest darkest Kernow
If you ever did that to my cat, you'd not have a boat left, just a pile of smashed fibreglass. :mad:
Now as others have said get an ultrasonic device to deter them. :)
VicS
13 Jul 2002
You sick bastard.
Go find another forum if that's the sort of thing you want to post. We dont need you here
