slipknot
When you Antifoul, do you cover the end of the depth transducer? Does painting the end effect the operation of it?
yes, and no
I've never found the recommended water based ones in a small quantity.
I'm Coppercoated, and that's not recommended for the transducer. So I normally look in the boatyard skip, find a finished antifoul tin of whatever brand and formula, scrape out a brush and half, just to dab on the transducer. Seems to work, although maybe being surrounded by Coppercoat also helps to deter fauna and flora.
There is some thought that conventional antifoul could lead to the plastic becoming brittle.
Our transducer is mounted internally, and works perfectly through the thickness of the hull and antifouling, so i wouldn't expect a few layers of antifouling direct to the transducer head to have any effect at all.
