anti slip paint for cockpit
voyager35
17 Sep 2011
I am repainting the deck of my cat with a two pack Jotun paint and am using a Rust Oleum additive to give a fairly aggressive anti slip finish. Unfortunately if i use this on the cockpit seats it will be to rough on clothing and hands.
What i would like to use is the sort of finish that is already on the seats, which is a very thin layer of paint that is smooth and has a slightly rubbery feel. I have no idea what it, but all the all the marine paints i have seen advertised seem to be fairy thick and rough.
Any suggestions on what type of paint it might be would be appreciated. I assume it was applied about 15 years ago when the boat was last painted.
I have used International "Interdeck". I dont find it too rough on clothing or hands.
you can buy some outrageously over priced granuals to mix with any paint. a tiny bag is about £5.00.
It seems less sharp than simply adding sand.
I have seen sugar or salt sprinkled on to wet paint once dry wash the sugar off, leaving a roughish surface. A further coat of paint will seal and take the sharpness from the first coat of paint
Wouldn't want that on seats - I reckon it'd be pretty uncomfortable, especially in shorts.
On the other hand, you wouldn't slide off!
I've used fine dry sand before. Well-mixed in to any paint and regular stirring as you work. Is the OP brave enough to experiment?
This does work but has the problem of leaving small indents in the paint that collect fine particles of dirt. Not easy to keep clean.
I've used Epifanes Nonskid Deckcoating (or an earlier version thereof) for about a decade on a small section of cockpit floor (a hatch cover) which does not have moulded antlslip. It is not very rough to the feel, but when used underfoot does require periodic renewal. This product information sheet refers specifically to its being semigloss and to its not being 'too sharp a surface', and says that four colours are available: white, cream and two greys: epifanesnonskidpaint.pdf (flints.co.uk)
