chrisbitz
How does that work and who sells them?
it's called a bouy-friend... geddit?
You stab the ring on the bouy with it, and then pull it back, and it automagically puts a rope through the ring!
I have one + a very fine Bosco from Old VarnishHow does that work and who sells them?
If someone needs to use my mooring in an emergency situation and they use it in a proper seamanlike manner, I will have no objection.
But how can they if you've fitted some kind of heathrobinson rope cutter to it ?
This has to be a non starter.
Never heard of lassoing mooring buoy's
Being high sided we do it on mooring buoys with eyes when the tide is running or its windy. Then in comfort and safety we can pass a rope through the eye and release the lasso. On two occasions when there was no alternative and it was blowing and bouncy we just put 4 lassos over the buoy and rode to those overnight . Cannot see how that would damage a riser particularly as most are chain.
Why was there no alternative? Whose mooring was it?
I've never lassoed - how do you do it in a safe manner? It sounds a good idea as we have very high freeboard.
It's a bit old gaffer for my tastes, and growing the beard takes time.
We tie a rope of sufficient length to drop over the buoy to the bow cleats ensuring it passes underneath the pulpit . Then harnessed on we stand or kneel in the bow with the rope ,which has been brought back over the top of the pulpit , and drop over the buoy as we motor up to it then fall back with the tide/wind . If its temporary we just ensure that the rope goes through the fairleads either side. If longer and having the advantage of twin bow rollers we transfer the rope to these.
Thanks, very helpful, we have problems with buoys with a soft rope top eye or no pick up buoy, that method will work well.
