Twister_Ken
At the moment my AIS aerial sits on the pushpit. When the boat's in cruising config, the outboard is stowed on the pushpit right next to it. I believe that may be why, sometimes, I don't get an AIS signal from ships that are well with visual range - line of sight - until they are maybe two or three miles out.
I'm wondering whether to put the AIS aerial on a short mast, like these below from Glomex, not so much for extra range as to get it out of the shadow of the outboard. Masts are available in a range of lengths from 150mm to 2000mm.
Given that there's a robust mount that the current aerial is screwed to, how high does the panel reckon I can go before I'd need to add some bracing to the mast - a complication I'd like to avoid if poss.
Masts are available in stainless
or GRP.
Which do you reckon would be best?
or GRP.
