youen
How can you link a coaxial wire to an isolated backstay to get an efficient antenna ?Thanks
I want only to receive BBC or France inter on 198Khz AND 164 Khz in Galicia Spain
For wfax on ssb I've had decent reception just with the antenna of a portable reciever resting against a chainplate down below.I'm ready to be shot down in flames here, but assuming there are no isolators in the backstay, wouldn't you expect acceptable conductivity for a receiving aerial from the chainplate? I'd try running a single core wire from the centre of the radio's socket to a ring connector on one of the chainplate bolts. If it works satisfactorily, then it has the advantage of all the extra bits being below deck and not subject to the weather. If it doesn't work all you have to do is snip it off the ring connector...
Rob.
France Inter? thought that had been stood down.
