Antares 760 fresh water in hull
Scorpleo
22 Feb 2022
Hello I'm new here so please be kind ish. 😂
I get water in the front compartment of my 760 where its double skinned , it is not sea water but definitely not clean water ( may be getting contaminated on the way there) Does anybody else have this issue?
Is it a leak from the upper decks 🤷‍♂️ I cant see anything obvious apart from the hatch lock has let in small amounts in the past as the water damage was evident on the fuel sender on the tank ; thanks in advance ,
Plum
6 Jun 2001
UK East Coast
Do you have a calorifier? If so, where does the water go to that comes out of the pressure releif valve. As standard, it drains into that void.
