Rangerman
Active Member
Hi All, Anyone know the shaft size and prop anode size on Anteres 30 fitted with the 370 Volvo ?
Cheers and regards
Cheers and regards
my antarise 9 is 40mm shaft would asume yours to be the same.Hi All, Anyone know the shaft size and prop anode size on Anteres 30 fitted with the 370 Volvo ?
Cheers and regards
Just measure the shaft diameter on the inside of the boat. That dimension is the anode size you need.Hi All, Anyone know the shaft size and prop anode size on Anteres 30 fitted with the 370 Volvo ?
Cheers and regards
That would be the thing to do, I was trying to get the size before I went down to the boat so I could order the anode, have a quick lift out and scrub then back in, but with the lock down now it will have to wait.Just measure the shaft diameter on the inside of the boat. That dimension is the anode size you need.
Www.solocoastalsailing.co.uk
[/QUOTE
