RJJ
...because COLREGS come into force in particular when there's risk of a close-quarters situation.I'm not sure why it's relevant that there is no provision for green to green in ColRegs. I go "green to green" with dozens of vessels every day. The fact that it's not mentioned in ColRegs seems irrelevant.
Richard
Yes, you go green to green perfectly safely because the intentions of both yachts are clear and also it's clear by eyeball or by bearings that you are well on track to miss each other. Also (I'm guessing) we're generally talking about small vessels that can in extremis stop in within 50m (3-4 boat lengths for most of us); if you alter course with 200m or 300m to go, there's time for the other yacht to respond and indeed change their mind four times.
If bearing is constant, COLREGS are clear and a turn to starboard is strongly advised for a give-way vessel, or for a head-to-head situation for both vessels. There's a good reason for that, which is to avoid exactly what happened in this incident.
