Another Chinaspacher Question.....
Major_Clanger
15 Oct 2016
Home is Norfolk, boat either Suffolk or Cornwall
I'm wondering if there's any way to lower the output on the generic Chinaspachers? The one on Vim is 5Kw-8Kw but even on its lowest setting the cabin becomes so hot that I have to go outside in the cold - rather defeats the object! It's made worse because she's a Co26 and so has little space to warm-up in the first place.
Any ideas please? I've seen 3Kw motherboards on eBay but not sure if that's the way ahead.
Do you have a thermostat on it? Do you duct the heat around - if it’s split up and relatively inefficiently spread around it is less intense than blowing it all out the front.
I tried a smaller sized 2kw chinaspacher, from the same manufacturer as my big 5kw sized 2kw (5kw chassis, 2kw motherboard and matching controller). I found the smaller one a lot louder for airflow, so I went back to the larger one.
I bought a lower volume diesel pump, about 16ml instead of the usual 22ml supplied with most. It lowered the heat output, and I found I needed to turn the heater up a notch or two above minimum, which helped with avoiding it coking up.
I like that idea, especially as it wouldn't be on tick-over all the time. Thanks for the tip!
