Nudge
The boat is ashore for the past couple of weeks with mains power on but the battery isolators off but the charging system mistakenly left on. When I was on the boat today, I switched on the 12 volt and all seemed to be well. Then the audio system which had the radio on stopped working and wouldn't switch on again. Then the VHF which had been receiving some traffic lost it's display and had only static.
Realising that there was likely to be a common problem, I tried to power up the instruments and no power there either. I then isolated all the batteries and discovered that the engine battery was very warm although the domestic bank seemed OK.
Switched on the domestic system only and everything returned to normal.
Is this simply the engine battery knackered? All batteries came with the boat to me so are probably 10 years old. All are 105AH as far as I can recall.
Advice gratefully received.
