ripvan1
VicS in case you didn't read query t'other day, any info gratefully received
Quote:
Originally Posted by VicS
It is not now considered correct or wise to bond everything underwater in this fashion. Only items that require the protection of anodes should be bonded to them.
Bronze and DZR through hulls do not need the protection of anodes and should not be bonded to anything, or even to each other.
Interconnecting underwater fittings can provide a low resistance path through the vessel for stray currents in the water.
Anything going pink is doing so due to dezincification. Bronze does not suffer from this because it does not contain zinc. It is something that only happens to brass.
Anything showing signs of zincification is therefore brass is best replaced with bronze or at least with dezincification resistant (DZR) brass if the effect is more than surface deep
Be aware however that there is now a trend for builders to fit brass through hulls with a life expectancy of 5 years!
Vic - that's very interesting - I have all bronze underwater fittings, prop and shaft, p/bracket, rudder and shaft and 1 through hull.
I'm about to launch soon and have been asking around about anoding and general consensus is that I need to employ some. (I bought the boat as resto project and out of the water - she was previously only in freshwater I believe, so no anodes present)
Can you point me in the direction of some literature that backs up your views please?
